It is currently Sat Jan 20, 2018 6:05 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: studio preamp IIC+
PostPosted: Sun Apr 16, 2017 10:04 am
so I did a sound test today and hooked everything up... Sound is very much ok but I noticed when I put the preamp in the splawn return fx loop jack my front panel volume controls do nothing (splawn doesn't have an overall master volume and mine is an older one so it doesn't has the fx volume pot). I need to set the volume with the output on my studio preamp...
I am thinking that is probably because the volume control of the splawn is located in the preamp section rather than the power amp section of the amp?
If I drive the output of my preamp high/hot in the fx return I should be safe? Nothing can explode lol ?
thanks
PostPosted: Sun Apr 16, 2017 11:32 pm
https://www.flickr.com/photos/100168049 ... ed-public/
Here's a nice set-up. Heavy mother, 250 pounds including the speaker cabinet, a Road Ready 4X12 EV loaded, never ending headroom.
I recommend getting a BBE 822A and placing it between the SP & 295, it made a lot of goodness happen, I can't imagine not having it. Total "pillow off the speaker" unit.
Hendrix/Dimebag influenced, JP2C, Mark llC++, Steinberger GR4's
PostPosted: Mon Apr 17, 2017 1:41 pm
thanks
Yes, the volume on your Splawn is probably at the beginning of the circuit, which means you're coming in after it when you patch into the effects loop. The power amp is basically running full tilt all the time, so controlling overall level with the SP is the right thing to do, and no, you can't damage anything by doing this.
PostPosted: Tue Apr 18, 2017 1:35 pm
I am going to pick up a mesa simul 295 this weekend nearby. This will be a better combination than slaving the preamp through my fx loop. Anything I should keep an eye on these older units besides tube life?
Thanks all !
PostPosted: Tue Apr 18, 2017 4:39 pm
Something of that era will be approaching the age where it would benefit from a recap job, if it's not there already, so there is some potential maintenance to consider. It's the case with anything that's getting around 30 years old. I never worried about that with my 395 though, and it was a monster.
