It is currently Wed Jan 24, 2018 6:32 am
 Post subject: Dumb Question
PostPosted: Wed Apr 05, 2017 9:41 pm
Hi Fellow Boogie Enthusiasts-
I have a Mark V head, and recently I blew a fuse. Thus, I replaced the fuse and a pair of my power tubes (it was obvious which one had blown) with a matched pair of 6L6's.
My dumb question is, if I didn't capture which pair I replaced, is there any way to determine the new pair from the old? Should I just wait until another tube goes?
Sorry for the dumb question, but I thought I should ask before blindly replacing tubes.
Thanks.
 Post subject: Re: Dumb Question
PostPosted: Sat Apr 08, 2017 12:57 am
sometimes when a power tube goes it will take a resistor or two with it. sometimes not. if a rectifier tube goes,,the fuse will blow but usually no resistors go. if you replaced a power tube and the amp works fine, you probably don't have a problem. Mesa's are pretty tough amps...
When Gibsons are outlawed, only outlaws will have Gibsons
