It is currently Thu Aug 16, 2018 4:53 am
 Post subject: Clean vol trim
PostPosted: Fri Feb 24, 2017 6:20 am
Hi!
Does anybody else have their clean trim always set for may clean volume and still need to boost it with a pedal to get parity with the gain channel? The clean channel sounds good but I just wonder if something is wrong? Mine's a 2x12 combo.
Thanks 8)
 Post subject: Re: Clean vol trim
PostPosted: Thu Mar 02, 2017 8:25 pm
If you have the Volume(gain) set low then the clean channel won't be loud enough, even with the clean trim set all the way up. Balance the volume across all three modes by turning the Volume control up in the 1:00 - 1:00 range, depending on guitars, pickups, overdrive or boost pedals, etc. Extreme settings of the volume control will yield wildly differing volumes across the three modes.
Electra Dyne 1x12 combo
Deluxe Reverb Reissue
American Deluxe strat
PRS Custom 22
