Alucardtes said:
Any suggestions on how to eliminate the hum that I get from the effects loop? Noise suppression pedals don't work for me btw. Also my distortion isn't as "good" as some people I hear demonstrating the head online. Early 2000's Triple Rectifier btw.
Can you explain your rig?
Are you powering pedals in front of the amp and in the loop with the same power supply? I get a ground loop hum from a One Spot if I use it in both places. An isolated power supply is the answer, or use batteries for one location or the other, if this applies. The pedals that normally go into the front are better on batteries, since distortion, overdrive, or compression require less current to operate.
