Help: Pedal/Channel MIDI Switching Triple Rectifier
Guitar and bass FX discussion
nlee89
Post by nlee89 » Wed Apr 15, 2015 11:27 am
Hi, I am trying to figure out which pieces of equipment I will need in order to program my pedals/fx to specific channels of my Triple Rectifier.
From what I understand, I will need a MIDI controller as well as a MIDI interface?
I primarily use Channel 3 with this configuration: guitar-overdrive-noise gate-compressor-noise gate-Triple Rectifier
However I would like to seamlessly switch channels without having to toggle on/off my overdrive and noise gate pedals.
What products would you guys recommend? I have heard the Behringer FCB1010 is good?
Thanks for your help!
afu
Re: Help: Pedal/Channel MIDI Switching Triple Rectifier
Post by afu » Sun Jun 28, 2015 11:48 am
I haven't used a Behringer, but I understand it works well. The dual pedals are a nice touch.
There is also something like Switch DR. This has 3 amp functions, pedal switching loops, and midi effects control. If three amp functions are not enough:
http://www.decibel11.com/Loop-Expander-.html
http://www.voodoolab.com/controlswitcher.htm
I have the Voodoo Amp Controller and a TC Electronic Nova System. The Nova has weird, dual function switches. This makes it difficult to time the switching correctly for a couple reasons; so I'm also looking for a solution, because I love the effects. I'm kind of hung up on the Behringer and the Switch Dr, but I might get both. The Behr has the foot pedals for pitch shifting and volume and the Switch Dr has the loops for switching pedals in and out. I mainly need a good relay system and some effects control, so the Switch Dr or something like it are winning. An variable control can be added later.
My Humble Music Tech Blog:
Dual Rectifier Index
jdurso
Post by jdurso » Sun Oct 04, 2015 9:20 pm
I have an RJM RG-16 that does exactly that. I have mine listed for sale in the classifieds section.
_______________________________________
Amps: LSC 1x12
Cabs: Basson 2x12
Guitars: PRS "McBraz" Brazilian McCarty
Pedals: Bogner Uber
