EL34 vs 6L6
I need to get some new power tubes for my dual rectifier. It has the bias switch for EL34 or 6L6, so I can put in either.
Just curious of big differences. Also, if anyone has any favorite brands. I play primarily metal.
I prefer Tung-Sol EL34s in my Electra Dyne. I've only tried those and Mullards, and still prefer the TS. They seemed a little brighter than the Mullards, and the ED is a pretty dark amp. YMMV.
For metal use 6l6, they cut through much better and like the other guy said, the bottom end is much better, clearer.
Do you mean the EL34B's?
How about matching tubes? Do they need to be matched?
Also, if I use the same tube style ie: EL34's, can I use different brands at the same time?
I've explored these, now that SED has stopped producing tubes and I really like them. I have a pair in my closet for when I run out of my =C= EL34s.
I've tried it with a Triple Recto, and my Roadster ,and felt the differences were very subtle with high gain in Vintage or Modern.
http://youtu.be/IPTtbk-b1H4
Dom
