winston_blue
- Joined
- Feb 3, 2015
- Messages
- 2
- Reaction score
- 0
Hi everyone. I'm new to this fabulous forum. I checked every thread to find if anyone already left some lines about the resolution of my problem, but seems I'm the only one affected.
So... I'm impressed by the tone of this little amp, but unfortunately I can't deal with squeal/feedback problems that start when output volume is set on 2 while using the lead channel.
My guitar is loaded with a Di Marzio Crunch Lab in bridge position and a Liquifire on the neck.
I tried everything: potted the humbuckers, changed the tubes (with expert technicians) to find out if valves could be responsible for that, checked the board to see if there were bad soldered connections, checked guitar electronics to see if components failures were present... But everything seems to be just fine.
It's kinda odd: squeals are present only with my guitar, but not with others...
Can someone help me to find out a solution?
Thanks
Thanks
