New Mesa Express. No need for all my pedals now
bridger
I recently purchased a Mesa Express 5;50 plus and now have no need for any of my "dirt" pedals. I'm wondering for those who had similar experience , which pedals did you keep?
I'm thinking just delay/chorus type, otherwise the Mesa covers everything else.
Depends on music you play. I use maxxon 808 with mine for fluid solos.
For the most part I'm an all-amp player myself. I have a Mesa Grid Slammer I use on top of the clean channel; gives me that "third channel" option that's somewhere between the OD channel and the clean channel, either of which I'm using more often than when I use the pedal. So, yeah, for the most part, I have no need for OD pedals, yet I understand that others do for their own purposes.
Depends on your situation. In a "originals" band I played yeah I had my clean and dirt channel and that is all I needed. In a cover band covering different styles 2 sounds might not cut it. This is where dirt pedals will help you cover more ground.
I had the same experience when I first "discovered" Mesa amps. But after a while I learned that there is still a small percentage, maybe 10-15 percent, of sounds/tones that I hear in my head that I can't dial in on any of the amps I've owned.....and there are a few pedals that move me closer to those elusive 10% tones. So rather than do without those sounds, I did eventually go back to an OD of some sort.
What I really noticed is that having a good amp almost eliminates OD pedal GAS. I've settled on 2 or 3 that I wouldn't mind owning, but I am quite content to only own one of them at a time, and I feel little or no need to switch any time soon.
Still love me a touch of Voodoo Lab Giggity, which is supposedly more of a preamp pedal than an OD, but it's great for a quick extra bite or crunch. Still love the CmatMods stuff, especially the Butah. Love the Analogman TS9DX, and oddly the Allums modded OD3 or ODB3 is quite useful.
New Express 5:25 owner here. I've removed my Jan Ray clone from my pedal board, compressor might go next. I kept my Klon Klone as it does amazing things on the blues channel. Nice to consider I may have only 3 pedals (klone, chorus (for Scofield stuff) and delay) now since the Express has such amazing tonal options.
