How to install a bias pot in a Rectifier
nakedzen
Re: How to install a bias pot in a Rectifier
Post by nakedzen » Mon Feb 17, 2014 4:40 am
Gnarkill3k6 wrote:When you're able to change something that was fixed... that means it's variable/adjustable and not fixed anymore, right?
Fixed bias = it stays where it's set. The other variety are the cathode bias amps that adjust the bias automatically.
http://www.thetubestore.com/Resources/M ... Bias-Types
mat.corona
Post by mat.corona » Mon Aug 25, 2014 12:36 pm
Hi,
Has anyone found the Mouser part number of the Bourns pot (pannel mount)?
I'm writing from Italy, I wish to order it in europe if it's possible.
Anyone can help me?
Any suggestion of other brands good quality pots?
Best regards.
Matteo
mat.corona
Post by mat.corona » Mon Aug 25, 2014 4:32 pm
For exemple. Is this one a good choice?
http://www.tubesandmore.com/products/R-VPEC-50KL
Thanx
Matteo
afu
Post by afu » Wed Jun 03, 2015 1:34 pm
mat.corona wrote:For exemple. Is this one a good choice?
Thanx
Matteo
Yes. The power dissipated is about 144 milliwatts. So a 2W pot will be fine and that one looks like a quality part.
My Humble Music Tech Blog:
Dual Rectifier Index
RussB
Post by RussB » Sat Mar 03, 2018 11:20 am
I notice that photophuckit hijacked my pictures, so I'll repost...
I installed a bias pot in my Single Recto today. I used a 50k pot with a 1/2 watt 47k resistor in parallel with the two outside legs. Leg 1 and 2 of the pot are tied together. I used the legs of the resistor to attach the pot to.
I removed the factory 22k resistor (to the right of the 220uf/63v bias cap, just above the 30uf/500v blue cap for the screen supply) and installed the pot assembly in the next "spot" over because it's easier to solder there... :lol: Electrically, it's the same connection.
I have EL-34's in my amp. For really good reason, I "hardwired" the power tube socket board.
