It is currently Sat Aug 18, 2018 2:45 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
PostPosted: Sun Feb 09, 2014 5:10 pm
Hi,
Picked up this Boogie trying to determine some
more info. Especially which pre amp tubes
are V1,V2, and V3. Looks like a 60 watt with EQ.
This Boogie is a whole tone beast. Waiting on some new tubes!
This is my 2nd Mesa, also have a Blue Angel 12" combo.
Thanks.
PostPosted: Sun Feb 09, 2014 5:23 pm
Send & return on a Mark I? Can you post gut pictures?
PostPosted: Mon Feb 10, 2014 3:07 am
Actually never pulled a chassis from a cabinet.
And yes that's is a send/ return effects loop.
Hence why I decided to post some pictures.
Like I said before I was trying to ID the correct V1, V2, and V3 locations.
I work at the shop where I purchased it. I will talk with a local repairman.
Thanks.
PostPosted: Wed Feb 12, 2014 12:09 am
V1 on a Mesa will be the preamp tube closest to the input jack.
There is never enough time to be in a hurry.
Currently in possesion:
Dual Caliber DC-5 1-12
Gone but not forgotten:
Subway Rocket
Blue Angel 1-12
Mesa Maverick 1-12
Subway Blues
.22 Caliber
Mark IIIC Simul-class head w/reverb and eq
PostPosted: Wed Feb 12, 2014 1:23 pm
Wow! I'd love to see a gut shot (and under the chassis shot) of that, as well. I've never seen a Boogie with such a bare rear panel. In fact, I am wondering if it really is a Boogie and not some kind of knockoff.... Does it actaully have "Mesa Boogie" inscribed anywhere?
PostPosted: Thu Feb 13, 2014 7:19 am
Hi,
V1 could also be the Fetron design and U might find a fetron switch under the chassis where the tubes mount.
Those tube-holder look much too new to be original, and I've not seen an original with them.
re fake or not - it looks so close to my own Mk1 that I had to do a double-take on the front pic..
Also agree - that rear panel looks funny without the dymo labels..
Lastly, agree with the other guys - guts shots would be superb. 4 screws on the top to remove chassis but be ready for the weight - those trannies weigh a lot..
Dave
Mk I,export,GEQ,cream
Mk IIA,exp,rev,cream
Mk IIB,exp,rev, tweed
Mk IIB,exp, rev,GEQ,simul, black
Mk III head,rev,GEQ,cream
Mesa Studio 22+, fan
Kitty Hawk M1 head
Fender 75, exp, 1973,15".
Fender 6G6A Bandmaster 1962
Fender AA763 Bandmaster 1964
PostPosted: Thu Feb 13, 2014 11:09 am
Total mystery amp.
PostPosted: Sat Feb 22, 2014 12:05 pm
Facing the back of the amp, look along the black right post that supports the chassis. There should be a serial number stamped into the wood along the side that faces the left post. Is there any writing on the top of the chassis? If you do take the chassis out, you could use the numbers found on the transformers, pots etc. to further date the amp. The presence and info found on any of the printed circuit boards can also provide clues. All the best and congrats.
PostPosted: Mon Mar 06, 2017 5:11 pm
A few years ago and now finally some chassis pics.
I sent photos to Boogie and Trent repiled that it is a Mark II, because 60 watt and EQ.
However I'm skeptical and would seek assistane from the Grailtone knowledge bank.
There a felt tip pen marking on the side of the chassis 12-10 55 G ". Please clink on the link at the bottom of the chassis gut shots.
[imImageg][/img]
[urlImage][/url]
http://s1017.photobucket.com/user/uberd ... sort=3&o=2
PostPosted: Mon Mar 06, 2017 7:40 pm
Definitely a mark 1.The 60 watt Mark 1 was known as the super sixty.Only after the mark 2 which introduced channel switching was it referred to as the mark 1.Surley these guys should know the history of their own amps?The Mark 1's were also available as 100w too.
PostPosted: Mon Mar 06, 2017 7:43 pm
SSG means probably 60 Watt and GEQ but I cannot guess what the middle S stands for.
Maybe, it is: Super Sixty GraphicEQ
Daniel
PostPosted: Mon Mar 06, 2017 8:34 pm
Thanks for the replies. I sell guitars, pedals and amps so I like to do research to get the right
info the next buyer. So I was shocked with the initial reply from Boogie. I sent another photo
of the rear panel and told them this is no serial number to trace. I requested if there was someone like Mike Bendinelli
I could speak with who would have greater historical knowledge. Stay tuned!
PostPosted: Tue Mar 07, 2017 9:49 am
that's a 74'-75' Mark I... the dress work and component type give it away.
they didn't exclusively use dymo labels back then.
dymos show up with consistency at the end of 1975.
for serial number they used a metallic "property tag" sticker which has fallen off.
looks beautifully all original except for the B+ caps
you have a lovely early piece of boogie history there.
here's a gut shot of my 74' Mark I, it was sold some time ago to a board member here. you can see the build similarities...
PostPosted: Tue Mar 07, 2017 12:14 pm
Not sure where the confusion came from, but yes - clearly your amp is a (mostly original) Mark I (No lead drive/lead master and 2 input jacks). Thanks!
PostPosted: Tue Mar 07, 2017 3:37 pm
No worries about the confusion. I'm replacing one of the 220uF 300v
caps. Also the EV 12 weight has caused the baffle some issues. Will upgrade
with stainless steel screws with securing on the backside. Which one are the
the B+caps?
Users browsing this forum: Wayno and 4 guests
