Thank you guys again for all of your help!
I have several presets programmed in for some of our songs.
I had some noise issues, so I ended up getting an Ebtech HE-2 & a Hosa TRS 8 cable snake (couldn't find a 4 cable snake).
One thing I noticed though, is that my amp sounds completely different with the 4 cable method.
I do not like what it does to the clean channel! The amp seems to loose all of it's sparkle and it breaks up faster.
Also, the lead channel sounds more grainy and not nearly as crunchy with the 4CM.
Maybe the levels need adjusting a little more. They are slightly different from the White Pages settings. Loop level is lower and the headroom is at 6db.
I think I will give my ears a rest tonight and try it again tomorrow after work.
I am leaning toward running my guitar straight into the amp and only using the G in the loop. That might be the ticket for getting the amp's tone back to where it should be.
