Mini Rec big enough to gig?
Great Ant
Do you guys think that a 25 watt will be loud enough to gig with two drummers. Live wise I'll be mic'd, but it's more rehearsals that I'd be worried about. I ask because i play with two drummers and It's my first band and I'm still learning about band dynamics.
Cheers
If you have it cranked and like the gain tones with it blasting, then yes, it will do fine with a loud drummer in a practice situation. Just don't expect to have any clean tones available. In terms of gigs, most places I play have PA systems. If you gig in places with the same, then you can just have them mic you up. This way, you'll have both, cleans AND gain tones at your pleasure.
+1
I've gigged with a 40 watts combo, a 50 watts half stack and even a 120 watts full stack... Never I could cranck any of these amps to our rehearsal volume. NEVER.
I bet the upcoming mini recto will be loud enough to 99% bar gigs out there.
As BostonRedSox said above, most places out there have PA systems. I have yet to meet a soundman that will let you cranck your amp onstage and then mic it. They may even ask you to turn around your cab or put a blancket over it.
I never used my MV on 90W mode live!!! So, i bet the answer is Yes!!
I bet this **** thing will sound great!!!
ned said:
Let the PA do the work and put some guitar in your monitor.
In a perfect world, yes. But in most small bar venues only drums and vocals go in the mix for us. The guitars self amplify, and the degree of that changes from venue to venue. Most times we're standing right on top of our gear. But a 20W head cranked would probably be fine...especially if you push it thru a 2x12 or 4x12 cab.
:shock:
Even the small bar gigs I played had a mic on the guitars.
Nothing like having part of the band come through the PA, and the rest from the stage. :roll:
I've played a very few gigs where just the vocals were in the PA, but those were in places small enough for a 25W amp.
Most places worth playing should have a PA to put the guitars in.
Dom
like most others ..for sure
i've never done a gig that the bass and guitars werent through the PA . and 25w can be loud as hell anyway
my mates AC30 is friggen loud
FWIW, I have need of the 90watt mode on my Electra Dyne. To create half the loudness on an amp, you have to cut the power by 10 fold. So a 100watt amp sounds twice as loud as a 10watt amp. 25 watts is only marginally quieter than 45 watts and I don't turn my 'Dyne up above 8:30 live on the master. If you are worried about being heard, play though a 4 x 12. Those are plenty loud!!
Bass frequencies are omni-directional so at a small venue a bass amp can carry. But guitar speakers are very directional, not putting the guitar in the PA will create a bad mix for everyone not standing in front of the guitar amp.
Vox AC30 should be louder. Those are class A 30 watts! Which are a lot louder than class A/B 30 watts.
You'll be fine for gigging. Just don't expect great clean headroom. For practices though, you might have some trouble being heard.
After 2 rehearsals with the Mini, I can confirm: The Mini Rectifier is loud enough :mrgreen:
Even on 10 watts mode on the Modern channel.
