How do you use the Standby ? I mean, how long do you leave your amp on Standby between sets ? Is there a maximum amount of time after wich it is better to close the amp ? As I understand it, the tubes stay hot when in Standby so I would like to know what's happening then, the pros and cons of putting on Standby vs closing and reopening the amp.
Is this different with each type of tubes : preamp tubes, power tubes, and in this case between EL-84, 6L6, etc. ?
This is not a Transatlantic specific question, I guess, but in case, I have a TA-30 and also a Traynor YCV 50.
