TA-15 Saves The Day
mule#1
Rochester NY
My band opened for Blues Traveler last night. Were supposed to play for one hour on the big outdoor stage before BT then play 2 hours inside the casino after their set is done. I set up my MKIV inside and do a sound check so we are ready to roll. Outside I plan on using my 50+. When I fire up the 50+ I have problems, no sound. Luckily I've got my TA-15 and have to use that as its show time. A 5,000 plus crowd outside and I use it on the 25 watt setting. It sounded amazing and was plenty loud enough on stage. It's a great amp to have as a back up!
I will hopefully have some video clips to post.
Funny thing is now I find it was a hookup error so there was no problem with my 50+. At least I know the TA-30 is a good backup. :lol:
I,ve been thinking about a TA-30, love to hear how you like it? a video would be great. I only play in little bars so I guess it's time to stop using 100 and 50 watt amps, stupid at this point IMHO. Thanks for the post
twally said:
Have you gigged the amp any more?
Just wondering how it sounds and cuts through in a gig.
I have and it sounds great. Plenty of gain and cuts through nicely. I have to fix the title of this because its actually the TA-15 not the 30. I had the 30 on my mind at the time. I generally use one of my other amps but if space if you need an easy load in this is nice!
