Impedance Mismatch
DavidE
I know the amp can tolerate certain mismatches, but I have two 8 ohm cabs and no parallel box. Can I safely plug one into the 8 ohm output and the other into the 4 ohm output?
Get a second opinion but in theory I think that's ok: I'm no expert but my understanding is that as long as the ohms load on the speaker isn't less than the output on the amp you don’t damage the output stage of the amp. 4 ohm output into an 8 ohm speaker is fine as far as I understand it.
However, someone way cleverer than me needs to clarify whether or not it’s safe to use both the amp’s speaker outputs at the same time.
Well, I tried it anyway and actually preferred the sound of the Thiele only so that's what I'm going to go with. ;-) I still may need the answer for other speaker cabs.
Its been a while since I learned this stuff but I thnk if the amp is perfectly matched with a single 4 or 8 ohm speaker in the appropriate output then using both at the same time will result in a mismatch (reflect back a combined lower load to the primary winding of the OP transformer) and cause more power to be dissipated in the output tubes - potentially reducing the life of the tubes.
can't you just chain the cabs together and run them out of the 4 ohm output? (most cabs, in my experience, allow you to do this)
(1/R equivalent) = (1/R1) + (1/R2)
So you would have 1/8 + 1/8, which is 2/8, which is the same as 1/4. So your total resistance would end up being 4 ohms.
http://www.1728.com/resistrs.htm
That works if one of the cabs has two jacks. In this case, both have only one. But it turns out I liked the sound of the Thiele by itself better than both together so the issue became moot.
Help !!! Im ashamed that I do not know this stuff, but it is what it is, and I dont want to hurt my new equipment.
My MB TA15 has a 4 ohm and a 9 ohm out jack. My new REC series MB 2 x 12 Cab (that was a floor model and did not come with a manual)
has two input jacks......one for 4 and one for 8. From reading on here, I understand I can do the 8 ohm out on the amp to the
4 ohm in on the cab and it will sound different, but no harm will come to my equipment. So I guess its also ok to do a 4 out on the amp into
the 4 in on the amp, but never a 4 out on amp into the 8 in on cab.
WHat are the differences I will experience in sound when I do any of the above and what is safe and the recommended ?? I have only done the 8 out and 8 in so far.
Thank you for your help and info!!!
Sorry I've been away from this board for a while so did not see this - but you have it the wrong way around. It is safe to plug a higher Ohms speaker input into a lower Ohms output on the amp (eg 8 Ohm speaker into 4 Ohm output) the result will be a little less volume and sometimes a warmer tone. A perfect match is naturally 8 Ohm to 8 Ohm or 4 Ohm to 4 Ohm this is how the amp was designed to operate and gives the loudest output. A potentially harmful mismatch is to have the amp drive a lower Ohm speaker than the rated output this causes the tubes to dissipate more power as internal heat.
Hope that helps
For anyone with doubts on this topic I put an Excel sheet on another forum that will help you calculate the total impedace, even using the different outputs of the amp.
http://www.marshallforum.com/attachments/cabinets-speakers/5440d1304382047-using-different-impedance-outputs-math-speaker-cab-hookup.zip
Always check what you are doing and read the manual :) The sheet is just a calculation tool and does not replace checking the connection and feasibility.
By the way: One 8 Ohm cab into each output is not OK. It's like plugging in an 5,33 Ohm cab into the 8 Ohm output.
Good you didn't like it.
