Hi. I've got a 1980 Mark IIB. EVM12L. Great sound. I've got three issues that I'm looking for help with. One of them's probably not fixable, but I figure I'll throw it out there, anyway:
1) When I'm in Lead mode, the reverb begins to cut out as I dial down the amount of distortion in the Lead Drive pot. Volume 1 is at "8", so there's plenty of break up there, if I want it. The cut becomes really noticeable when the pot's at 6 or below. It's bothersome when I switch from the clean channel, as the loss of reverb's pretty noticeable. I've been getting around that by using a RealTube pedal for the subtle overdrive (reverb stays constant) and the Boogie Lead drive at 8 for the heavier stuff, which keeps the reverb constant there.
2) I've got the stereo footswitch for EQ and Gain (wish it was the treble pull out pot and not the gain...anyone know if I can do that?). Sometimes I get an annoying *POP* when I switch into the EQ. Sometimes not. I'd love to get rid of that.
3) Along the same lines, I get a pop when I switch in and out of lead mode. This doesn't seem fixable, though...so I make sure I blunt the strings before making that change, which gets rid of the pop. Be nice if someone knew a different fix for that.
I had a mod done to the lead drive which kicks it up a couple of notches. I love both channels.
Thanks for your time, people.
Bob
Bob
