Hi,I bough a boss ME50,but when I opend the box,found only the pedal,& the manual,no cables nothing,any body can tell me how to connect it to my ampli,do I have to buy some kind of cables,and how to be connected to the guitar.thank you
god plus you son,fo your adviceOctavarius said:Dude, you seriously have to post threads in the right section. Personally, I don't mind, but it would at least strategically benefit on your part in making the chances better of getting a good, detailed reply quicker. :wink:
Just curious,Markofzeebop said:I use the ME 50 with my Lonestar classic 2-12 combo. You have two options and you should try them both to see which works better for you. 1) guitar into ME 50 input and left channel of stereo ME 50 output into the input of the amp. 2) connect the EFFECTS LOOP SEND jack on the rear of the AMP to the input of the ME 50 and then connect the output jack of the ME 50 (left channel) to the EFFECTS LOOP RECEIVE jack on the rear of the AMP. Plug your guitar into the instrument input of the AMP and make sure that the EFFECTS LOOP IN/OUT toggle switch on the rear of the amp has the loop IN. I use option 2.
