I am intending to use a TCElectronics G-System that I have, so would have to use the rear panel FX Loop for that.
Does anyone have this setup who can clarify the correct way to connect it up.
So far it appears that the ACE/G-System connections are:
AMP 'Input' (front panel) ---------------------- G-SYSTEM 'Insert Send'
AMP 'FX Loop Send' (rear panel) --------------- G-SYSTEM 'Insert Return'
AMP 'FX Loop Return' (rear panel) ---------------G-SYSTEM 'Output' (Left/Mono)
Any furher help gratefully received.
