• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
    You can become a Supporting Member which comes with a decal or just click here to donate.
FS: MINT condition Road King II - 2x12 Combo
BoogieMan_SC
sAwesome, versatile and monstrous amp. Mesa's flagship 4-channel amp equipped with EL34's and 6L6's that are switchable per channel in addition to allowing blending of the 2 tube types if desired! This description doesn't even begin to scratch the surface, there's also your choice of solid-state or tube rectifiers, switchable power (120/100/50 watts!), different cabinet selections per channel, etc, etc.
Comes with cover and casters and King Controller foot control, cords, etc. No rips, tears in the tolex, etc. Black in color. MINT condition (never left the house)
Specs/Info from M-B site: http://www.mesaboogie.com/Product_Info/Rectifier_Series/roadking/roadking.htm
Reviews: http://www.mesaboogie.com/Reviews/RoadKing-Guitarworld/GuitarWorldRoadKing.htm
http://www.musicplayers.com/reviews/guitars/2006/0906_MesaBoogieRoadKing.php
PRICE: $1,750 (via PP gift, or USMO, or check, but it must 1st clear) shipped to your door in the lower 48.
You can check out my 100% feedback rating on Ebay, for 13 years and nearly 1,000 transactions:
http://myworld.ebay.com/2000racer
Specs:
Handbuilt in Petaluma, California
Multi-Watt™ Channel Assignable Power Amp with Progressive Linkage™ (patent 5,559,469)
4x6L6 & 2xEL34, which allows you to select either 2x6L6, 2xEL34, 2x6L6+2xEL34, 4x6L6 or 4x6L6+2xEL34 for Power Ratings of 50, 100 & 120 Watts! / 6x12AX7, 2x5U4
Fixed Bias for Consistent, Maintenance Free Performance
4 Fully Independent Channels with 12 Modes (Channel 1 =Clean, Fat or Tweed™, Channel 2 =Clean, Fat or Brit, Channels 3 & 4=Raw, Vintage High Gain or Modern High Gain)
Each Channel features Independent Gain, Treble, Mid, Bass, Presence, All-Tube Long Spring Reverb, 5 Position Progressive Linkage Power Tube Select (choices listed above), Channel Assignable Dual Rectification with Recto Tracking™ (Diode or Tube Tracking -- Patents 5,168,438 & 7,193,458), Speaker Output Select (Speaker Out A, B or A+B), FX Loop 1 and 2 Select (2-Series Loop On/Off Switches per Channel or Footswitch Assignable)
Output Level Control (over all channels when activated)
Footswitchable Solo Level Control -- Patent 6,724,897 (over all channels when activated)
Bold/Spongy "Variac" Switch (Patent 5,091,700)
True "Hard" Bypass Switch that removes FX Loop, Output Level & Solo Level Controls from signal path
Turner Output with Footswitchable Mute
Slave Out w/Level Control
Fan Cooled
External Switching Jacks for Channels 1, 2, 3, 4, Solo, Reverb, Loop 1, Loop 2 & Tuner Mute
Includes:
9 Button Footswitch (Channel 1, Channel 2, Channel 3, Channel 4, Solo, Reverb,
Slip Cover
Absolutely no issues with it...all tubes literally changed 3 months ago (over $250 cost).
