Hi all,
I am looking for an all in one recording and live solution that will enable me to send a post IR signal to the interface/FOH whilst monitoring with my cab at attenuated volumes.
I was hoping to use the reactive load of the CabClone (via Speaker Out input) and route the slave out from my Mark V to the Line In, however the manual states that both of the inputs cannot be used simultaneously.
My understanding is the Cabclone attenuator is not reactive. What implications does this have on the processed signal? Would the processed signal whilst using the attenuator be different than say using the reactive load for IR's and sending a line out to an external poweramp for volume control?
My goal is retain the highest quality signal through both the cab and DI. Is the the CabClone IR+ the solution?
Any thoughts, corrections or suggestions will be appreciated.
