What footswitches will work with Dual Rec
Posted: Tue Feb 11, 2020 6:07 pm
by Jordan44
Hello. I just recently purchased a used Dual Rectifier 3 channel. The amp did not come with a footswitch. I see roadster footswitches for sale however no actual dual rectifier ones. Can anybody tell me what footswitches will work on my amp? Thank you!
Re: What footswitches will work with Dual Rec
Posted: Sat Feb 29, 2020 3:22 pm
by Archon
3 Channel Non Multi-Watt: https://store.mesaboogie.com/products/f ... -watt.html
3 Channel Multi-Watt: https://store.mesaboogie.com/products/f ... ifier.html
Look on Reverb or eBay. You might find a used one for cheaper. The older ones look like this:
You also need a 7 pin Din cable like this: https://store.mesaboogie.com/products/c ... 25-ft.html
Hosa makes a cheaper one that works too. Hope this helps.
