What footswitches will work with Dual Rec
Jordan44
Hello. I just recently purchased a used Dual Rectifier 3 channel. The amp did not come with a footswitch. I see roadster footswitches for sale however no actual dual rectifier ones. Can anybody tell me what footswitches will work on my amp? Thank you!
3 Channel Non Multi-Watt: https://store.mesaboogie.com/products/footswitch-3-channel-dual-triple-rectifier-non-multi-watt.html
3 Channel Multi-Watt: https://store.mesaboogie.com/products/footswitch-3-channel-multi-watt-dual-triple-rectifier.html
Look on Reverb or eBay. You might find a used one for cheaper. The older ones look like this:
You also need a 7 pin Din cable like this: https://store.mesaboogie.com/products/cable-7-pin-din-male-male-25-ft.html
Hosa makes a cheaper one that works too. Hope this helps.
