FluxDrive w/ Strymon Flint problem
Bottle Rocket, V-1, V-twin.
Footcontrollers, midi switchers, amp switchers and Mesa Boogie products not covered.
green_henry
Post by green_henry » Fri Jul 22, 2016 11:28 pm
Hi,
I have been using a FluxDrive in front of my Blue Angel for a while now and it has always sounded great.
I picked up a Strymon Flint and put that in front of the Blue Angel and it sounds fantasic too.
I finally got around to using the FluxDrive and the Strymon together, in front of the amp, and it sounds great when the FluxDrive is on, but as soon as I turn the FluxDrive off, the volume drops to barely audible. At first I thought it might be a battery issue with the FluxDrive but it behaves exactly the same way with a power supply (the Strymon is always using a power supply).
I can move the Strymon to the effects loop, but I like the simpler up-front setup. Am I doing something wrong? Is there some hidden toggle switch on the FluxDrive or the Strymon that I don't know about?
Thanks
Maverick 2x12 | Blue Angel 2x10 | Flux Drive | G&L ASAT Classic | Fender '68 Reissue Strat | EBMM Luke
flantrax
Re: FluxDrive w/ Strymon Flint problem
Post by flantrax » Sun Nov 06, 2016 6:42 pm
Is your Strymon in true bypass or buffered bypass? Might be a buffer issue.
Does it happen if you swap the order of your Flint/Mesa? I found so dirt pedals like a buffer after them and that can cause volume drops(at least I've experienced that in my rigs from time to time)
green_henry
Post by green_henry » Sun Nov 06, 2016 7:05 pm
It was a circumstantial issue (for lack of a better term). Normally, I have my effects chain all setup before I power up the amp. On the few occasions when I experienced this problem, I was swapping different pedals (a FluxDrive and a Big Muff) into the chain while everything was powered up.
