It is currently Sun Dec 16, 2018 6:37 am
PostPosted: Mon Nov 16, 2015 10:20 pm
This question has probably been answered in the past but for the sake of possibly leading to other q's i will ask anyway.
I have a 2001 Triple Triple and when i use the Big Foot it SEEMS everything is working properly, EXCEPT the FX on/off switch. Now, if i assign the loop to a channel from the rear, that channel receives the effects. Channel switching, Solo Boost all function as designed. I have a reverb and delay pedal in the Loop but cannot switch them On or Off using the Big Foot...is this normal or do i have an issue. Any suggestions are greatly appreciated.
PostPosted: Sat Mar 19, 2016 8:13 pm
Bump
PostPosted: Tue Mar 29, 2016 12:19 am
The 'Assign' knob on the back of the amp needs to be set to FTSW. Otherwise the FX button on your footcontroller will not work.
