Throttle Box Eq - Power Supply
nebularaler
Hello good people!
I have just bought Throttle Box Eq pedal and I wonder which power adapter/pedal power supply would be suitable for it. I do have Boss PSA 9V adapter but I'm not sure if it will be fine. Don't want to spoil the pedal so I'm not using an adapter until I'm fully sure. Any advise is highly appreciated!! :)
Regards.
You'll be fine. The Mesa pedal (as are most pedals) is 9v center negative. Your Boss power supply is 9v center negative, and it should have more than enough mA to drive the pedal.
