Step Up solution to convert 110v US to EU 220v effect box
Cadavre
Been looking for a Dynacord CLS-222 in good condition for a few months. Found one in Italy and purchased it. Problem is that has a 220v power requirement.
Seeking advice on a suitable external transformer that will not introduce any noise into the signal.
Sent the local Mesa Boogie Tech a message asking if there might be a mod he could engineer a solution that would eliminate the need for an external transformer. Any advice on that appreciated.
Current modulators are mono in/ stereo (mono + mono) out. Use a splitter from the TA's send for the mono box inputs and a passive analog mixer/splitter that receive the A/B (requires two channels) outputs from the boxes and then combined/summed through the mixer/splitter's A/B main outs to the TA's A/B return ports.
The 222 has A/B ins and A/B outs. Should the 222's A/B inputs connect between the mixer A/B main outs and TA A/B returns, or, could it be placed between the TA's A/B outputs and the 2:90 A/B inputs?
Thanks
