TC Electronics Ditto Looper and Mini Recto
Woodsgirl
Michigan
I'm not very well versed on pedal placement. Where and how should I hook this up on my Mini Rec. In the effects loop jack or the front?
http://www.sweetwater.com/store/detail/DittoLooper?device=c&network=g&matchtype=&gclid=CPSfj-jVpbsCFU_NOgodZDwATw
There aren't any rules, but generally speaking most players put modulation and time-based effects in the FX loop. One of the reasons is that, again, most people prefer those effects after distortion/OD/fuzz, and if you're using the amp's OD, putting them in the loop accomplishes that mission (so you're looping your OD rather than OD'ing your loop/delay, etc.). For people who use OD pedals, they generally place them up front after their OD pedals.
But, again, there are no rules. Do what sounds best to you.
