TS9 settings
Dino.
*DELETE*
I bought a TS9 today and figured out the best settings.
Gain -off
Tone - 12:00
Level - maxed
Sounds KILLER!
I don't know why Mesa doesn't just incorporate the TS circuit in their amps.
THIS is what a Mesa should sound like! :D
mate the ts9 is killer in front of any gain device, i see it like an eq device!
Dino. said:
*DELETE*
Gain -off
Tone - 12:00
Level - maxed
Sounds KILLER!
I don't know why Mesa doesn't just incorporate the TS circuit in their amps...
They did the next best thing and made their own TS-type pedal. They call it the Grid Slammer. :wink:
That may be, but I still don't understand why there should be any need for an overdrive/boost pedal with a Rectifier. Why don't the gain controls on the amp allow the same tight response and help add sustain without the need of a TS-type pedal? And in reading through a lot of these threads, it appears that most Rectifier users recognize what the amp is lacking by adding these TS-type pedals. Mesa offering their own line of pedals really doesn't address the issue with the amp circuitry. As a matter of fact, I see it as an acknowledgement that their amps are truly lacking something. The gain control within the amps circuit is pretty much useless when set beyond 12:00-1:00, IMO.
I dunno ... I just find it odd.
There isn't, at least for me and my Mini Rec. I can't say anything about what others find useful or not with Minis or the bigger Rectos.
The Mini has way more gain/sustain on tap than I'll ever need. I think that the Minis are tighter than the big Rectos. I'm no amp guru, but I believe it has something to do with the SS rectifier and the EL84 power section.
I think that's true for a lot of the guys using the big Rectos; I've read the same things. Again, I don't know how other people are using their amps, but I suspect that many are "scooping" a lot of mids out for the chugga-chugga, and then find themselves buried in the mix when it's time to solo; hence, a mid-boost pedal like a TS - nothing says "jumping out of the mix" like midrange. I've had a play around with a Dual Rec and I found it to be quite nice in the mids when EQ'd properly, leading me to believe that a lot of the complaints I read about Rectos are more "operator error" than any inherent deficiencies of the amp itself. Of course, that is just my "belief."
Well, considering that there are other Mesa amps than just the Rectos, I don't see that as a valid premise. It also assumes that Mesa made their pedals strictly for Mesa amp users. I have no idea what the breakdown is of people using Mesa pedals with Mesa amps vs. with other amps, but I'm sure that not everybody who has a Mesa pedal is using it with a Mesa amp.
I use the Grid Slammer as a sort of "third channel" with the Mini Rec. I use the "clean" setting so that with the guitar volume wide open there's a bit of hair/crunch yet clean when it's rolled back. The Grid Slammer is used as a "boost" for that clean channel setting, with pretty much the same settings you found appealing with the TS (full level, zero gain). I set the red channel "vintage" for my full-on lead tone. It's very close to an early Mark series Boogie in terms of being "liquid" and having a good amount of mid range punch and endless sustain. I get that with the gain at maybe 9-10 o'clock and the master at 2-3 o'clock.
I wouldn't know. For the kind of music I play and the sound I'm going for I can't fathom having the gain set that high on the red channel. I do run the gain that high on the Mini, on the clean channel where, in larger venues my favorite setting is on "clean" with the gain and master dimed; then I treat the amp just like an old NMV Marshall and just ride the guitar volume from clean to mean. Otherwise gain around noon-1 o'clock, master at 2 o'clock on clean.
Good luck in your quest.
My quest was over when I bought the TS9 pedal. :wink:
The issue I have with my Dual Recto has nothing to do with EQ or mids.
It has to do with the amount of usable gain in the amp's circuit.
I don't use the TS9 as a distortion pedal and when I think of the term "boost", I think volume.
And I certainly don't use the pedal as any sort of volume boost.
When using my choice settings (gain=0 / tone= 12:00 / level= max), the pedal just pushes the amp to where I'm able to achieve a more balanced, tighter gain.
This also lends increased sustain for leads that I could never achieve with the amp itself.
Having said that, the TS9 is by far the best investment I could have ever made.
After using a boost in front of my Dual Rectifier for over 6 years I pulled my OD808 out of my signal chain and really sat down one day and tweaked my settings. I no longer have any use for the OD808 in my Mesa rig now. Does the TS style drive reign in the amp? To a degree it does, but you can get the same effect with tweaking the amp's eq and rolling off the gain.
As far as sustain being added by a OD type pedal, it pales in comparison to using a compression pedal. One of these isn't a necessity either.
It was mentioned that a lot of guys might be playing a scooped eq'ed amp to chug the metal stuff. I play blackened death metal almost exclusively and in no way do I scoop the mids. If anything on my amp is scooped it is treble. My go to settings for rhythm are:
P:11:00
V:11:30-12:30
G:11:00-11:30(venue/humidity dependant)
B:1:00-2:00
M:2:00-3:00
T:10:30-11:30
Ch:3 Modern/Silicon/Bold
Lead channel is set the same but reverse the B and T and up the P to around 1:00 CH:2 Modern
