V-Twin saturation problem
Virolin
Hi, I have a Mesa B. V-Twin with 2 12AX7A tubes. I haven't use it for a long time, and now Iam facing this problem.
When I move the knobs gain & master till half path (12 O'clock) Iam start to notice a saturation noise, that becomes more evident when rise the gain or master a bit.
I had cleaned the pots, but that is not the problem. I have swiched & replace the tubes with other 12AX7 and the problem is still there.
Iam guessing what it could be. Capacitors seems Ok & in good shape. they are not inflated. Maybe some OpAmp? Maybe a bad soldering?.
Any help is welcome.
Thanks in advance.
I bought a v-twin pedal used and it was noisy like that. I just assumed it was common.
