Controlling two amps with one switch?
brentf64
I have a Mesa Heartbreaker and a 50 Cal + that I run in stereo. Would it be possible to use some sort of splitter to switch both amps channels at the same time? I tried it with an adapter but it was a stereo y splitter and did not work. I was thinking a mono splitter might work but wanted to check here first. Thanks.
You could build a dual switch that has the two switches close enough together so that you could stomp them at the same time.
If you use midi, an Axess CFX4 could do it.
A DPDT throw footswitch might work, one pole for each amp.
