V Twin problem
FEUD
UK
Hi
Hope you guys can help me out!
I have just bought a V Twin pedal from ebay, but all I get is massive hum from it. No guitar signal is coming through at all, apart from the headphones output, an thats only when in bypass mode.
I've changed the valves, run it through headphones directly, but still the same problem.
Anyone had similar problems/know what this is?
Thanks in advance!
Try to open it and look inside.
Look at the wiring, if you're lucky your Twin just got attacked by the cable-unsoldering Pokémon :)
I bought one used and it did the same thing. I sent mine to Mesa, but I could of fixed it myself because it was just a bad solder joint @ the mode switch. Open it up and check the board, might be what straitouttahell said.
