Footswitch Cable for a Dual Rectifier?
the_meridian
NJ
Is this a MIDI cable? It looks like it's shaped the same, and it has 7-pins. The reason I ask, is because I want a longer footswitch cable, so I can put it in a snake and save some setup time.
The only other thing I can think of it being would be a DIN, but the plug looks a little big to be DIN.
Can anyone verifiy this for me? That 12ft footswitch cable ain't cutting it.
-Ant
You can order a 30ft. 7pin DIN cable from Mesa, your local mesa dealer will order it in for you. and you can connect the two cables together like an extension cord.
If you go to your local electronics store they may be able to make you a cable but from my experience finding a 7pin din connector was difficult. 5 8 and 9 are the most common.
Also, I believe MIDI is a 5pin DIN setup.
