I just stumbled into this board, and found already lots of good info...
However, im looking for a schema for the footswitch of the MB DC5, which has the Lead / EQ switch on the front. I googled around, but cant seem to find it...
Basically what i need to figure out is this:
what switches what:
Does the front-tip of the jack-plug switch the lead or the EQ. Or does the middle-ring does this?
(When i look at the plug, it consists of 3 areas: the "front-tip", "middle-ring" and the rest to the end of the cable, usually used for grounding.
Sorry if I cannot make myself more clear, English is not my native language, especially when using technical terms... So providing me the right technical terms would be appreciated as well..
what switches what:
