Decent A/B box, that wont affect TONE Reccomendations
Bottle Rocket, V-1, V-twin.
Footcontrollers, midi switchers, amp switchers and Mesa Boogie products not covered.
zerofivefour
Post by zerofivefour » Wed Feb 02, 2005 2:58 am
I need a decent A/B box so I can switch between my RIG and a floor mounted Guitar Tuner. My concern is that the ab box doesnt have cheap wiring and or jacks that would alter my tone adversely. I dont want to spend a small fortune either. I'd rather get a rack mounted tuner if Im going to have to spend a bunch of cash to get a decent a/b box.
Any opinions of reccomendations?
Thanks, 054...
ned
Site Admin
Post by ned » Wed Feb 02, 2005 9:46 am
The one I have doesn't seem to effect my tone. Its kinda old, blue box with 3 jacks. I'll check the brand when I get home.
Ned
Erik
Post by Erik » Wed Feb 02, 2005 9:49 am
How much are you looking to spend...the Korg DTR-1000 is a great rack mounted tuner that will run you a little over $100 or so.
zerofivefour
Post by zerofivefour » Wed Feb 02, 2005 12:09 pm
Erik:
I dont really want to spend more than 30 bucks on an a/b box(I'm hoping to get a used one on Ebay). I know that isn't very much money, but as I said I'd rather spend the money on rack tuner if the a/b box solution goes beyond 30 bucks. I have been considering picking up either a Sabine 7000 or a Korg DTR 1000 recently. However I just built a pedal board and thought this might be a better more cost effective solution.
Ned:
would the 'blue box' you have happen to be a DOD 270 a/b box? If so this would be a reasonalby priced box. There are currently a few on ebay atm that I might bid on.
My main concern remains Not affecting the signal path to my Dual Rectifier Rackmount =)
Thanks for your replies.
054...
ned
Site Admin
Post by ned » Wed Feb 02, 2005 12:38 pm
Thats exactly what it is. I bought it so long ago I've got no idea what the price was.
Ned
zerofivefour
Post by zerofivefour » Sat Feb 05, 2005 12:59 am
Well I found a very good quality a/b box at http://www.loop-master.com
here is a direct url to the a/b box page, I think there are 6 variations, some with and without LED's
http://www.loop-master.com/catalog/default.php?cPath=23
I actually found a better solution to my tuner problem. Ive decided to purachase a dual loop true bypass box from loop master which has a tuner out as well. This will allow me to place my wah in one loop and any other effects in the other loop, as well as have a dedicated line going direct to my tuner for tuning with out any tone degradation.
Here is a link to the item I purcased.
http://www.loop-master.com/catalog/prod ... ucts_id=60
054...
RussB
Post by RussB » Sat Feb 05, 2005 1:52 am
Looks like a good unit...
My old Whirlwind A/B/Y box crapped out, and I'm looking for a replacement. I found these guys as well...decisions decisions
http://www.loooper.com/
zerofivefour
Loop-Master.com highly Reccomended
Post by zerofivefour » Tue Feb 15, 2005 2:26 am
IT's worth every penny !
I recieved the Loop box. This is an awesome addition to my pedal board.
The build quality is Solid. The functionality Flawless. Anyone interested in removing the TONE SUCKAGE from their current pedal board set up should seriously check these boxes out. The owner is such a cool guy to deal with too. Shipping was an absolute steal. Absolutely great purchase through and through.
I absolutely reccommend the unit.
I've orded the pedal board patch unit also,
My pedal board is getting there =)
054...
www.loop-master.com
musicbox
Post by musicbox » Fri Feb 18, 2005 4:39 pm
i can tell you that you DON'T want the morley aby box. pops when switching as its passive and theres crossover between the two amps. its cheap, but you get what you pay for.
Ampcab
Post by Ampcab » Sun Feb 27, 2005 2:43 pm
Hey even better, check out these guys.
http://www.audiotechusa.com
Godless
Post by Godless » Wed Mar 09, 2005 11:46 am
Hey musicbox I use the morley and i don't experience any pops when i switch or tone coloring.discoloring at all, mybe my setup has something to do with it though?
gtr 1 ----morley A input/gtr 2 morley B input----out to ns-2 gate---to wah
----to amp.
vulture2600
Post by vulture2600 » Mon Apr 11, 2005 2:34 pm
ive heard similar stories about the morley being not so good. the
whirlwind is transformer isolated, worth 100 bucks!
rack tuners should have a thru-jack that would allow you to pass your
signal thru to your fx or the like. they also have a footswitchable
mute function that you could control with a midi relay (cfx4 from axess)
Ibanez RG470-EMG 81/85 18volts
Ibanez RG570-EMG 89/SA/89
Mesa Boogie F30 1x12 custom vinyl
Marshall JCM 900 / 1960A 4x12
Line6 ToneCore Echo Park
Ampcab
Post by Ampcab » Sat Apr 23, 2005 10:40 pm
The Whirlwind is not transformer isolated. And Morley DOES suck bad!!
Audiotech has the CL2 whcih allows you to turn the "MUTE" on a rack tuner on and off. MIDI is a bit much for a solution. Costly for a simple task.
Ampcab
Post by Ampcab » Sat Apr 23, 2005 10:42 pm
Forgot to give you their address. Sorry...
www.audiotechusa.com A lot of the pro guys use their ABY. Check out their site. It rocks!!
telecasterkid
Post by telecasterkid » Wed Jun 01, 2005 9:35 am
www.loooper.com David Boggs is the MAN!!!
I own a custom built A/B/Y with tuner mute. This is simply the BEST A/B/Y I have ever used in all my years of playing. I have owned the Morley and Whirlwind and Rapco and I'm telling you when you hear the loooper you will simply throw the rest of them in the trash.
I hooked it up to a Road King and a Laney VH100R two high gain amps and it is Quiet!!! No pops, clicks, stalls, noise, etc.
Plus David is a real class act to deal with. He will build what you want with lots of options available.
Highly recommended!!!
Check him out!!!
