Mesa Mark IV - External Switching Problem with RJM Mini Amp Gizmo
Bottle Rocket, V-1, V-twin.
Footcontrollers, midi switchers, amp switchers and Mesa Boogie products not covered.
yillars
Post by yillars » Fri Jul 10, 2020 1:48 pm
I have Mesa Mark IV Head version: A
I've recently bought an RJM Mini Amp Gizmo in order to switch the amp using Midi Signals.
There is a rotary switcher back of the amp (FT. SW + R1 + R2 + R3 + EX. SW) and I chose EX SW which is the correct settings to be able to use external switchers.
There are 4 cables from the Amp Gizmo;
(1. channel) (TRS) - Red -> Connected to Lead Input
(3. channel) (TRS) - Blue -> Connected to R1 Input
(5. channel) (TRS) - White -> Connected to R2 Input
(7. channel) (TRS) - Yellow -> Connected to FX Loop Input
And I put my FX Racks to the Switchable FX Loop I/O. I'm not using Normal FX Loop I/O.
When I turned off all the signals of the Amp Gizmo, I could hear a clean sound but there is no indicator on any channel which is OK.
When I turned on only 1. signal, I hear Lead sound without FX Loop which is perfect.
When I turned on only 3. signal, I hear R1 sound without FX Loop which is also perfect.
Same for 5. signal, I can hear R2 sound only.
So, when I trigger 1. signal and 7. signal which I expect to hear Lead + FX Loop, I hear only feedback. But if I turned off 1. signal which is Lead, and will let 7. signal alone then I'll hear FX Loop + Clean. Because on the backside of the amp there is a section where you can combine the FX Loop to any channel. For instance, you can combine FX + Lead or FX + R1 or FX + EMPTY which I currently set.
I already checked the manual but I couldn't find anything there.
That's what I want to have;
(1. ) -> Lead
(1. + 7. ) -> Lead + FX
(3. ) -> R1
(3. + 7. ) -> R1 + FX
(5.) -> R2
(5. + 7. ) -> R2 + FX
(7. ) -> On any channel I want to be able to turn on and off.
I hope I can find an answer and here you can find a clip;
https://streamable.com/639g8r
Thanks
Eevil
Re: Mesa Mark IV - External Switching Problem with RJM Mini Amp Gizmo
Post by Eevil » Fri Jul 10, 2020 1:55 pm
Hi.
Can you test the switch combinations with dummy plugs or shorted cables? So you could check the correct switch combinations first without the unit :) and after you’ve figured those out would be easier to program the gizmo. IMO
Current:
- Diezel D-Moll
- Electra-Dyne 1x12 23” combo
- Studio preamp
- 2x12 Recto horizontal
- 4x12 Stiletto slanted
Gone:
- Mark III 60w/grx
- Express 5:25
- Roadster head
- Triaxis / 2:50
- Stiletto Deuce Stage 1&2
- CAA OD-50
- Mark V
