It is currently Tue Jun 19, 2018 6:57 pm
Post new topic Reply to topic  [ 1 post ]
 Post subject: Helix with Triple Rec.
PostPosted: Thu Sep 21, 2017 7:26 pm
I have an old 2 channel Triple Rectifier with the parallel loop.
What is the best method to hook up the Helix and be able to use the pre-amps on the Helix through the power amp section?
The standard 4 cable method seems to overlap tones, and when the loop is engaged (when the natural triple rectifier tone in engaged) it makes it so the effects in the chain aren't affecting the tone: For example, even if the delay is engaged the effect doesnt come through.
