When connecting the rectifier recording preamp correctly to the 2:100 rectifier poweramp it's suposed to sound like dual rectifier, but it does not!
With the exact same settings in modern/red mode the rack setup will sound alot brighter and have less mids.
I know there is a live/recording switch on the preamp but refering to the manual all it does it take away stuff, not add, so I that means ot should be set to live/bright. Setting it to warm kinda kill the sound when playing through a cabinett.
However...
The treble controll on the dual rectifier set to 12.00 o clock sounds like the treble controll on the recto preamp set to minimum...really wierd...
I've double checked this with several units....di'd mesa make the treble controll on the recording preamp work like this by purpose?
However...
