2:90 with balanced input signal
Demon Of The Fall
Post by Demon Of The Fall » Sat Dec 30, 2017 12:52 pm
Hi all... I recently bought a custom 4x12 which is 8ohms mono and 4ohm stereo, I also own a 2x12 rectifier which is 8ohms... I would like to run the mark v in the 2x12 and use the slave out to feed both inputs of the 2:90.
I'll need to clone the signal from the slave out with an splitter like the radial LX-2... I also own a DI box countryman type 85.... both of theses option send a balanced signal...
The 2:90 can manage balanced signals?... thanks in advance.
Best regards
DZ
Mark V Combo Wine Taurus w/ Tan Jute Grille
Mark IV A Head
Racktifier Rev. G
Triaxis v2 TX4 Rev. D
Simul-Class 2:Ninety v1
2x12 Horizontal Rectifier
MesaMad1378
Re: 2:90 with balanced input signal
Post by MesaMad1378 » Mon Jan 01, 2018 12:26 am
Hi there,
Happy New Year
The inputs on the 2:90 are mono so sending the balanced signal to it will only go to it as a mono signal.
Not sure if you need to bridge the ring and the sleeve, as in TRS, to make the connection.
Cheers Brett
Mesa Dual Rectifier, TriAxis, Recto Recording,
2:90, 2:100, SUS-4 16ru Case,
Flux Five, Throttle Box EQ, 5 Band EQ,
Straight Traditional 4x12 Cabs.
And other stuff!!
Demon Of The Fall
Post by Demon Of The Fall » Thu Jan 04, 2018 1:28 pm
Hi Brett... Happy new year to you too... I'll keep looking into it.
Best regards
DZ
Mark IV A Head
Racktifier Rev. G
MesaMad1378
Post by MesaMad1378 » Thu Jan 04, 2018 3:31 pm
Hi There,
What are you sending balances signals from to the 2:90?
I had my G Major 2 in between my Mesa High Gain Amp Switcher and the 2:90, it has Balanced outputs that you just use a mono TR cable for and it works fine.
Cheers Brett
And other stuff!!
Demon Of The Fall
Post by Demon Of The Fall » Thu Jan 04, 2018 4:02 pm
MesaMad1378 wrote:Hi There,
I would like to use the slave output of the mark v to feed the 2:90 but I need to clone the signal first, and all splitters I been looking has balanced outputs, like the radial LX-2....
Mark IV A Head
Racktifier Rev. G
MesaMad1378
Post by MesaMad1378 » Sun Jan 07, 2018 9:07 am
Hi there,
An ABY pedal such as the Radial ABY will do it easily, I have one of these, they are good because they also have an isolator, phase reversal and ground lift switch, very handy.
I found that the slave out of my Dual Rectifier wasn’t very good, but that was to blend Amps to. I found the cab clone was better or my Webber attenuator.
Cheers
And other stuff!!
