Studio Preamp - Recto Poweramp
dtrax
Post by dtrax » Wed Nov 29, 2017 1:12 pm
I recently scored a SP in excellent working order, with normal cosmetic wear and tear for a piece this old (30 years give or take?). I've been running it through my Triple Rectifier power section for the time being. Sounds fantastic! I've come to the conclusion, for my taste, Red/Modern power configuration with Diode/Bold works best. I'm not really well versed with Mesa's rack gear in the past, and the only thing close in their current lineup is the 2:90. I'm not really sold on the the whole simul-class thing though. It does have "Modern" mode, which I'm guessing is NFB removed. I'll search for a schematic to compare it to my TR.
I'm in no real hurry, or need, but thinking ahead I'd like to have a complete rack setup.
So, any Mesa rackmount poweramp, past or present, that can come close to a Triple Recto power section?
Guitars:
Ibanez '98 RG7620 (EMG 81-7H, 60-7H)
Amps:
Triple Recto 3CH (modded), Studio Preamp (MK2C+ mods), 2x12 Recto Vertical cab
Past:
Mark V head, Rectoverb series 2 combo, F-30 combo, V-Twin rack pre
psihiatros
Re: Studio Preamp - Recto Poweramp
Post by psihiatros » Wed Nov 29, 2017 7:40 pm
Hei there,
Mesa 2:100 is what you need, now discontinued:
http://mesaboogie.com/support/out-of-pr ... power.html
It's the power section of a dual recto x2.
No rectifier tubes or bold-spongy switch though, but it is my understanding that you won't need them anyway :)
"I'd rather be hated for who I am, than loved for who I am not." Kurt Cobain (1967-1994)
CELESTIAL DOGMA (Electro music coming straight from the heart):
https://www.youtube.com/channel/UCHdQTR ... 4S1Vut6uCg
dtrax
Post by dtrax » Sun Dec 03, 2017 8:23 pm
Man, I totally forgot about those. I realize they're made for touring musicians, but it would have been nice to be able to run only one side and not have a load connected to both amps (e.g., independant power switches per side). Thanks for the heads up!
Guitars:
Amps:
Past:
psihiatros
Post by psihiatros » Sun Dec 17, 2017 9:20 pm
Sure, no problem :)
Hey, I just found out that Mesa had actually released a 4U rack stereo power amp wich was the power sections of 2x triple rectifiers.
It has 200w /ch :shock: :shock:
Apart from its rarity, you should play it alone in the North Pole in order to saturate the power tubes property :mrgreen:
The model is called: Coliseum 300.
Here it is:
http://www.mesaboogie.com/support/out-o ... m-300.html
vipmetal
Post by vipmetal » Tue Jan 16, 2018 9:36 am
Tony Iommi has said the Coliseum (probably Mark Coliseum head though) was too loud for small arenas they play.
— MESA AMPS —
Mesa Roadking (2002)&Mesa TriAxis (2015), Recto 4x12
Single Recto (2010), 2x12 Vertical
- past -
Triaxis 2.0 Recto-board
Recto Pre
2:50
Mark V
dtrax
Post by dtrax » Fri Mar 02, 2018 5:39 pm
https://www.ebay.com/itm/Mesa-Boogie-Co ... Sw0j9ZWr7m
If money were no object I'd buy it in a heart beat. :idea:
Guitars:
Amps:
Past:
IronSean
Post by IronSean » Wed Apr 18, 2018 11:24 am
dtrax wrote:Man, I totally forgot about those. I realize they're made for touring musicians, but it would have been nice to be able to run only one side and not have a load connected to both amps (e.g., independant power switches per side). Thanks for the heads up!
On many of the Mesa power amps you can run just one side by leaving the other side (Don't quote me on this) in standby with the presence and volume rolled down. The real instructions and if it applies to the 2:100 should be online, maybe even in a Mesa FAQ, but also if you contact Mesa or read the manual it should clarify.
Actually, pulled up the manual here and on the top of Page 6 it says the following:
NOTE: If you opt to use only one channel of the 2:100 with speakers connected to that
channel’s output only, you must turn the unused channel’s level control to zero! Otherwise the channel will be operating without
a load, and damage to the tubes and/or the transformer will result.
Mark V
Studio Preamp
formerly: Quad Preamp, Rocket 44 112
