New Triaxis - PO's mod?
Posted: Wed Jun 21, 2017 8:08 pm
by Jonelli
So, I got one finally, it's an original version SN# T0449. There's a DC connector added just above the power cable. Does anybody know why they would have done that? Is this something that was common by some? I have already tested the unit on AC power and it works just fine. I'm just curious about the added DC connector and why they would have done that.
Re: New Triaxis - PO's mod?
Posted: Wed Jun 21, 2017 11:19 pm
by JMMP
Pretty sure that's to plug in your MIDI footcontroller's power supply so you can phantom power it with a 7-pin cable.
Posted: Mon Jul 10, 2017 12:51 pm
by xcpointx
Yep, that would be correct.
You plug the end of a 9V transformer into that and it sends signal down the middle pin of the midi in cable to power your midi controller remotely (see the middle pin?). This saves you running a walwart on the floor and to your midi controller.
