It is currently Tue Jan 22, 2019 1:30 am
 Post subject: TriAxis FX loop issue
PostPosted: Thu May 04, 2017 4:11 pm
I have a G-Force going through the TriAxis FX loop.
Wired as follows:
TriAxis FX send > G-Force Left in
G-Force left output > TriAxis FX return A
G-Force right output > TriAxis FX return B
On the Triaxis when the FX loop is on i only hear the left channel, when the FX loop is off I only hear the right channel.
I'm at a loss.... And can't figure out why when i page through the SW/Loop settings on the TriAxis the above happens.
I have it wired in series at the moment, bypassing the FX loop altogether and it's working beautifully.... I'd really like to use the FX loop as the clarity of the G-Force is better it being a digital unit.
PostPosted: Fri May 05, 2017 4:58 am
Full disclosure: I do not work a stereo rig, nor do I own a G-Force - just a Gmajor2.
Assuming that you have verified the integrity of all the cables in the signal chain, have you tested the audio path when cabled up in Mono? For example:
    Tri FXS -> L-IN -> L-OUT -> Tri FXR-L
    Tri FXS -> R-IN -> R-OUT -> Tri FXR-L
    Tri FXS -> L-IN -> L-OUT -> Tri FXR-R
    Tri FXS -> R-IN -> R-OUT -> Tri FXR-R
This should verify that there are no connection issues on the Triaxis and that the G-Force is routing audio through both input/outputs.
True North Function Band
Ibanez JS10th
Ibanez RG752AHM NGD
Mesa Triaxis (V2, TX4D)
Mesa Simul-class 2:90 (V1)
TC G Major 2
TC 1128
Marshall 1912
PostPosted: Fri May 05, 2017 7:04 am
Right, I have triple checked all cables.... All hand soldered by me, no issues.
I have also checked the G-Force running in stereo in series, placing it between the pre-amp and the power amp.... All works really well.
I'll have to check your theory tonight as i'm work at the moment.
Andy
