2:100 modern mode...
vick1000
Post by vick1000 » Thu Feb 16, 2017 12:34 am
Is there a way to engage it without a Triaxis or Recto preamp?
r33per
Re: 2:100 modern mode...
Post by r33per » Thu Feb 16, 2017 3:45 am
The guy I bought my 2:90 from created an "always on" 6.3mm jack by connecting signal to ground and plugging it into the Modern insert (I think I've got that right...).
I guess the other way would be to use some other switching option on the likes of a TC G-System/Major or possibly rigging something up with the likes of an RJM Mini amp gizmo...
True North Function Band
Ibanez JS10th
Ibanez RG752AHM NGD
Mesa Triaxis (V2, TX4D)
Mesa Simul-class 2:90 (V1)
Marshall 1912
vick1000
Post by vick1000 » Thu Feb 16, 2017 3:56 am
So it just uses an open/closed signal like a footswitch?
JMMP
Post by JMMP » Thu Feb 16, 2017 7:47 pm
Exactly. You can use a GCX or other loop switcher as well.
Roadster, Mark IV, Electra-Dyne, Fillmore, Traditional/ Stiletto 412
Gone: Quad MIDI Pre, TriAxis V1 & V2, Formula Pre, 2:90, 20/20, JP-2C LTD, TA-15
vick1000
Post by vick1000 » Fri Feb 17, 2017 4:14 am
If that's the case, I think I'm just going to pull the jack off the panel, leave it hanging inside with a TS cable plugged into it (heat shrinked of course), and wire the cable end to a mini toggle, and mount it in the hole.
r33per
Post by r33per » Fri Feb 17, 2017 5:09 am
Love it - great idea.
I'm a total electronics n00b so any kinda of howtos and photos would be great. Very interested to know how this works out for you.
Ibanez JS10th
Ibanez RG752AHM NGD
Marshall 1912
vick1000
Post by vick1000 » Tue Feb 21, 2017 9:06 pm
OK, so the mini toggle replacing the jack is a no go, the jack is mounted on the I/O PCB with the rest of the jacks.
I made two solutions, one is a a 1/4" TS plug with the sleeve solder point cut down to about 1/4", and folded on top of the tip solder point, and soldered to it. I then glued two plastic 1/4" jack nuts back to back and tightened them down over the exposed solder joints, and filled the open portion with liquid electrical tape. This is of course an always on solution.
Then I cut down a plug much in the same way, and soldered the mini toggle legs directly to the plug, and heat shrinked the exposed connections. The amp sounds much better in modern mode.
My main concern however, is not only the fan. It is very loud, even though it does have a pleasant character. But the heat this thing generates is no joke, it could easily be used to heat a small room, I am not joking. So I am in the market for a better solution, maybe a 2:50/2:90 or Fryette/VHT.
vick1000
Post by vick1000 » Sun Feb 26, 2017 10:32 pm
Love this amp, it's just too hot and fan too loud for my needs. So I'll take her back to GC. Just ordered a 2:50 from Mesa Hollywood to replace her.
