Clean preset Distortion. Opinions needed
mikegguitars
Setup is a triaxis, swapped preamp tubes all Mesa and 2:90. It sounds like slightly blown speaker distortion (but it is not the speakers) striking a fat clean chord. Even after tube swap, identical. Where else would you look? I took all pedals out of loop and went straight in.
Not sure off the top of my head, but it'll be easier for the Grailtone hive-mind, if you post your settings.
If you can, try a different power amp. Also, try plugging directly into the 2:90 (bypass the TriAxis). You'll want to separate the Pre-Amp and power amp, to determine where the distortion is coming from.
~Icarusuki
