It is currently Sat May 26, 2018 12:54 am
PostPosted: Wed Feb 01, 2017 8:08 am
Setup is a triaxis, swapped preamp tubes all Mesa and 2:90. It sounds like slightly blown speaker distortion (but it is not the speakers) striking a fat clean chord. Even after tube swap, identical. Where else would you look? I took all pedals out of loop and went straight in.
PostPosted: Wed Feb 01, 2017 10:07 am
Not sure off the top of my head, but it'll be easier for the Grailtone hive-mind, if you post your settings.
If you can, try a different power amp. Also, try plugging directly into the 2:90 (bypass the TriAxis). You'll want to separate the Pre-Amp and power amp, to determine where the distortion is coming from.
~Icarusuki
PostPosted: Thu Feb 02, 2017 12:15 pm
+1. Settings, mode, 2:90 voicings etc. :)
True North Function Band
Ibanez JS10th
Ibanez RG752AHM NGD
Mesa Triaxis (V2, TX4D)
Mesa Simul-class 2:90 (V1)
TC G Major 2
TC 1128
Marshall 1912
PostPosted: Sun Feb 05, 2017 11:14 am
SOLVED. New preamp tubes across the board and its cooking nicely.
cron
