It is currently Sat May 26, 2018 12:57 am
 Post subject: Studio Pre troubles
PostPosted: Sun Nov 20, 2016 10:15 am
Hi all
I probably have an LDR-problem.
It is a come/go problem - sometimes it is powering up OK but after a while i get:
Noise, standbyswitch is "bypassed" - very thin and weak signal.
So: tapping on the top side of R211 - sometimes - makes the amp work correctly for a while.
That resistor is connected to LDR 2.
I will replace that resistor - but maybe also the other LDR resistors also?
Does anybody have a list and chart over which resistors that needs to be changed?
Also what type of resistors are used and their size in W.
Thanks in advance
ReidarNikolai
 Post subject: Re: Studio Pre troubles
PostPosted: Mon Dec 05, 2016 5:24 am
Do the LDRs first, search down I think I posted on how I replaced mine. That resistor you are tapping might just be resoldered.
PostPosted: Mon Dec 05, 2016 2:48 pm
Thanks for the heads up (and pictures).
Will try this ASAP
Get back when I have tried replacing the LDR´s.
ReidarNikolai
PostPosted: Mon Dec 12, 2016 3:08 pm
Replaced LDR 1, 2 and 3.
Everything is working as it should.
I will keep it open for a while - I am gonna give it a cap-job while I it is out of the rack.
Heads up about availability for those LDR´s the firm making them in the States have stopped doing so.
You can find cheaper ones on eBay from China - I don´t know how good they are.
Thanks
ReidarNikolai
