2:90 Thud sounds prior to and after re-tubing
Allegron
Post by Allegron » Tue Oct 25, 2016 3:42 pm
After many years of service in my project studio my 2:90 stereo amp is giving me fits.I started getting sizzling, sputtering sounds on Channel B. I tapped on the 6l6s to see if any tubes might be suspect. One 6l6 seemed to stick out, so I pulled it and found the base to be a bit loose. I replaced it with a 6l6 spare from my Mark IV. Things quieted down, then a couple days later I started getting "thuds" or very low frequency sputters from the speakers even with the volumes turned all the way down! I immediately ordered a matched quad of Svetlana 6l6s and a matched quad of EL-34 winged =C=tubes. Also a matched and balanced trio of JJ 12ax7as for inside the unit. Now the "thuds" still come and go, even with the volume all the way down or up at playing levels, (this has to be bad for the speaker cones), and also NOW Channel A IS ALMOST 50% LOWER IN VOLUME than channel B. I'm half sick over this. New tubes,loud thuds, flubs, and less volume in one channel? I'm going to trouble shoot by swapping back each original tube (minus two with loose bases.) Other than that I might send it to Petaluma for attention. I know I could have some "New" faulty tubes, even maybe a mismatch, but the low thuds are probably another issue. Anyone experienced a similar problem? By the way- A couple years ago I sent my Mark IV to Mesa for a handful of minor repairs. They did a great job and the amp sounds almost like new.( Made in 1991). Very reasonable rate also. Thanks everyone.
vitod
Re: 2:90 Thud sounds prior to and after re-tubing
Post by vitod » Sat Nov 05, 2016 2:40 pm
I had the same problem with a lower volume channel. It's pretty common unfortunately. I went to my local amp tech and he solved the problem. Your amp needs a complete checkup. No need to send to Boogie.
