triaxis question help
Mike B
Hi everyone,
Has anyone else with a triaxis ever have issue after issue?
I mean my 2008 triaxis has been to broken twice in 2 years.
the first time an ic chip failed =ic38, which caused half the LED
to go black, and now 2 years later the whole panel goes black except
for the 4 red SW lights and the green fx light. Those are staying on
and the unit has a ground hum without guitar signal. Is this a simple fix?
I mean I don't even play thru it that much and it's racked and never
moves from its location inside my home.
I got effect processors that are 20 years old that have been banged around and never had a problem
with any of those. It makes me wonder if I'm doing doing something wrong like the order it's turned
in in my rig. OR could those power wires on top go to the surge protector be causing it to breakdown? :shock:
I could move the surge protector under the triaxis?
Just seems like it shouldn't break down so much?
Anyone else with a triaxis experience multiple breakdowns within a few years?
thank you, everyone.
http://forum.grailtone.com/viewtopic.php?f=5&t=69957&p=489417#p489417
:roll: found same issue in the link above here on this forum.
same exact symptoms and time frame if anyone has same issue.
