lcwoods529
- Joined
- Jul 14, 2016
- Messages
- 25
- Reaction score
- 0
I'm sure this has been covered a billion times but, I can't find it or wrap my head around the explanations given. I need someone to explain this to like I'm an idiot
I want to run my Triaxis with a G-Major into the Mark V as the power amp. The reason I'm doing this is because I have a 2:90 that is in need of repair so I need a temporary setup.
OR, what is a simple way of using the G-Major with the Mk V?
I need to know exactly what input/output jacks each cable would be routed to. I had it working when I had the 2:90 in place but now that I'm going about it differently I can't seemt o get the G-Major and Triaxis to sync. I know the MK V is different animal is does not switch in the same manner.
Again, explain it to me like I'm a n00b. You need a degree to understand MIDI, I swear
