It is currently Sun Feb 25, 2018 6:53 pm
Post new topic Reply to topic  [ 12 posts ]
PostPosted: Fri Apr 15, 2016 3:39 pm
Hello guys,
I was wondering if some of you could share their Triaxis settings for the Load/Reload/Black album tones ?
Thank you.
PostPosted: Tue Apr 19, 2016 2:26 pm
Nobody ?
PostPosted: Fri Apr 22, 2016 10:10 am
Guess not....
PostPosted: Fri Apr 22, 2016 11:20 am
hydesg wrote:
Guess not....
No way ;-)
Well, I know that these albums are not the most appreciated but I love the tone and I can't be the only one ?
So Even Black album settings ?
PostPosted: Thu Jun 02, 2016 10:53 am
Well, Triaxis + Strategy 400 was the live tone of most of the 90s for Hetfield, as well as used in the Load albums as well. Don't forget that Het used 2 Triaxis together for his live sound back then - one on LD2 Yellow, the other on LD1 Red.
Settings? Depends on what else you're using. I'd recommend getting an external EQ to use in the loop instead of relying on the DV.
Boogie user of 20+ years, previous owner of 150+ Rectos, author of the previous "2 Channel Recto User Guide" and current "3 Channel Recto User Guide" (in progress).
PostPosted: Thu Jun 02, 2016 1:00 pm
Thanks !
So if I put an EQ in the Triaxis loop I can't put effects like delay or chorus, right ?
PostPosted: Thu Jun 02, 2016 7:41 pm
Road King
google has lots of archived images if u search around. anything from montyjay (a guy who used to have a metallica website) would be legit
'92 Dual Recto Rev. D, Volume mod
'84 Mark IIC+ Coliseum
'85 Mark IIC++ DRG, V1 mod
Mesa Standard 4x12
1980's EV Thiele
Sold:
'92 Dual Recto Rev. C
'92 Dual Recto Rev. E
'05 Dual Recto 3ch
'84 Mark IIC+ DR
http://www.TheBoogieArchives.com
PostPosted: Mon Jun 20, 2016 10:31 am
gobnew wrote:
Thanks !
You can string as much or as little in the loop as you want. James uses two Triaxis as mentioned before, and he also has a custom box with two Mesa 5-band EQs, one for each preamp. To start to get there with one, you will want the added flexibility of an EQ in the loop (probably before your chorus and delay if you use them), either a Mesa, or even an MXR 10-band for more flexibility. That'll give you more control than the "Dynamic" Eq thing the Triaxis has.
Mark V
Studio Preamp
formerly: Quad Preamp, Rocket 44 112
PostPosted: Tue Jun 21, 2016 1:32 am
PostPosted: Wed Dec 14, 2016 1:13 pm
I use a Mesa eq after the Triaxis before it goes into the TC G Major 2. It sounds better than in the loop, I also have it in a loop on a Voodoo Labs GCX so that I can turn it off and on, cleans and Mark1 sounds are better without eq. I have the Triaxis on Ld2 Yellow, Gain 6-8, Treble 7, Middle 3.5, Bass 7, Lead 1 0, Lead 2 5-7, Master 7, Presence 7, Dynamic 1. I have the eq scooped mid and both trebles and basses pretty high, in the v configuration.
Mesa Dual Rectifier, TriAxis, Recto Recording,
2:90, 2:100, SUS-4 16ru Case,
Flux Five, Throttle Box EQ, 5 Band EQ,
Straight Traditional 4x12 Cabs.
And other stuff!!
PostPosted: Tue Dec 20, 2016 1:50 pm
Circling back to this topic. I've been playing with my Triaxis/Strategy 400 rig a lot lately, and if you're only going to use 1 Triaxis for the 90s Metallica sound, I think Lead 1 RED (TX4 Recto board, non-Fat) does the most convincing job by itself with an EQ in the loop.
PostPosted: Tue Dec 20, 2016 2:41 pm
Thanks for your tips guys :!:
