Hey,
I have a Triaxis connected to a power amp 2:90 with two cabs as it is shown in the manual wiring #1.
The problem is when Triaxis is turned on the Gain button works strangely - the decrease gain button (marked as 0) changes presets instead of, well, decreasing gain.
For example, I have a preset 01 where standard gain is 6. I would like to decrease it a bit, I press the 0 button and the preset changes to the second (02) and gain changes to 7.5. If I continuously press the decrease gain button the preset number grows.
Increase Gain button (1) works fine.
I am sure Triaxis is in the default mode, no Shifts or Entrs are pressed.
In the Shift mode the Gain buttons work fine, i.e. set the number of a preset or a program.
What might be a problem?
Thank you!
Thank you!
